I’m back here with another bug that makes me crazy.
I’ve a 6 shots animation with camera switch event to pass from one to the next. But when I add the 4th and 5th events, it’s like the first ones are diseabled and the 3 first shots are stuck with the ‘previous camera’ from the last event activated. It also erase the DOF info of the first camera, that I have to redo then.
Did you have a similar experience with camera switch animation?
I could replace the object in the scene with a cube to share you the file if needed.
Thanks.
EDIT: I’ve imported the file in a new scene with all datas, deleted all the switch and redo them, it seams to fix the bug.
