Rendering a laptop could be super fun.a little leaflet about the material,i used metalic paint of course,then add some texture,should put diffuse & specular on (brushed) pattern,leave bump & opacity be.now its time for a little manipulation,go to the diffuse header,sync width & height,enter the figure 0.12,then rotate the UV Angle 90°degree.now you’re good to go,also you can apply colore 1&2 on specular so it could reflect the closest light shade to the real model.oh don’t forget to turn off the sync for colores.Another hands_on tip to create this luminous light on lap top screen.you can duplicate the screenglass and make it some distance from manitore,and maby some rotations.U need to apply the material type on emissive to provide the natural light.almost forgot,turn-off the visible to camera icone.Have fun😊
