good morning
i need to clone 10 times an object composed by many other object.
when I use pattern command keyshot clone the object (I saw it from the scene menu) but the cloned objects do not appear. If I click ok I can see all cloned object are overlapping each other.
I can duplicate the object without problem.
if I try to create pattern of other obj present in the scene I’m able to clone it.
mmmmmm
help me please.
I’m not sure if any help but sometimes it takes quite a while to reflect the new situation when you use GPU. Maybe you can try CPU mode?
10x is not that much but if your object is really complicated it might help to switch mode. I’ve for example sometimes the GPU doesn’t show some changes and if I switch back to CPU and to GPU again I see them. Could also be the Nvidia driver I’m on, you actually need to use the one from September 2024 and I’m often on a newer version.
thanks Oscar.
I solved it like this: I moved the objects that I couldn’t clone with the pattern function into a new group, outside the main group. by doing so I was able to duplicate them.
after this I moved the new group (containing the duplicated objects) inside the main group
