render one or more objects "live"
good morning
I want to wnow if it is possible to render only selected or visible object on the scene. the resulting imagedimension must be the same size of the selected or visible object.
the goal is to know the overall dimension of all selected or visible object in the scene: these is because i dont know how to obtain from keyshot the size of the selected obj.
that’s all falks
You can select an item and put it in ‘solo’ mode with the right click menu, not sure if there’s a shortcut key for it.
But if you need dimensions, you can select the item and just select the properties tab like this:
Hi Oscar,
Thanks for always helping me! :smiley:
I didn’t explain myself well.
I have a keyshot scene with a series of objects and I want to know the total size, width, height and depth.
I can get the information for two dimensions (width and height or width and depth) but only by rendering and making the correct proportions (I can’t render images of several meters).
I would be better if I could extract the information from the keyshot scene, but at the moment I’m not able or maybe it’s not possible. if I select multiple objects (multiple selection) keyshot doesn’t give me the total size.
Put those objects in group.
right, thanks Oleksii
i thought at one point there was talk of a dimension tool that could be used to make a sort of engineering drawing with arrows and dimensions between parts and stuff. Would still be pretty neat to have.
