Volume Video Map
Hello fellow Keyshoters!
Has anyone an idea how to create a Volume Video Map?
VDBs are very fast and easy to make, but a volumetric animation with several VDBs? Is that possible?
Looking forward to hearing from you guys!
Cheers!
In the old forum was a topic that discussed and showed a script to update a VDB sequence. The basic idea was to use a VDB on a volume map. Then replace that VDB instance with the next one of the sequence. This method renders frame to merge later as video.
In combination with other animation nodes, this process is very limited.
Hmm, sounds interesting, but rather complicated…wondering if there is an easier way in newer versions of Keyshot, without scripting.
I guess it’s on the wishlist quite a while
