124 seems low since a single 3090 does close to 100. Wonder why it’s only 124. Do you also use the NVLink on the 3090’s so you are able to use 48GB for GPU renders on that machine?
What's your KeyShot Benchmark score?
I was thinking the same thing but I haven’t seen anyone make a comment. It should be higher as you suggested. I will add a NVLink and see what happens. Thank you!
A great value CPU vs KS results IMO:
I asked a Finnish friend if he could run the bench, he has that new 7900X3D but see it has less cores.
KeyShot Viewer 2023.1 Benchmark Result
CPU result: (AMD Ryzen 9 7900X3D 12-Core Processor - Threads: 24) 3.73
GPU result: (NVIDIA GeForce RTX 4090 with Driver: 531.41) 161.19
It’s weird how low his 4090 score is. But I think the benchmark is just way to short to give a good idea about GPU performance. This score should also be way higher looking at the single GPU’s performance of every card: What’s your KeyShot Benchmark score? - Best Practices - Luminaries
That is indeed a big difference. Maybe it is also depending on the KS and Viewer version. There have been differences in the past.
I like these challenges. But the UI in various areas could be improved to better understand how to upload items. Scrolling to the bottom of a very long page to find “Reply” instead of “Upload” or “Upload your Benchmark” isn’t very intuitive. Still, thanks for these challenges to push us to explore KeyShot functionality further.
Result
CPU 1.86
GPU 23.50
I’ve a bit the opposite, if I’m at the bottom of a page I have to scroll endless to see the menu again at the top. Would be nice if that menu bar was always visible. I now use that little slider at the right to go back to the top but I like a menu on a page.
Benchmark Results:
CPU: 5.7
GPU: 10
Keyshot Viewer Benchmark
Result
CPU 6.5
GPU 45.73
Got only the CPU score, my Quadro P4000 is not showing up here
![KeyShotViewer|431x339]
That’s odd, think it’s around 5.63 looking at this: https://community.keyshot.com/forum/t/whats-your-keyshot-benchmark-score/276/59
Is it possible to run the benchmark on KS11 Pro? Does the software version change results?
CPU 2.91
GPU 81.03
@jonathan.fernandini I think it does make a slight difference in results, you can download older versions of the viewer here: Direct Downloads | KeyShot
CPU result: (Intel® Core™ i9-9900K CPU @ 3.60GHz - Threads: 16) 1.78
GPU result: (NVIDIA TITAN X (Pascal) with Driver: 535.98) 12.54
KeyShot Viewer Benchmark Results:
CPU result: 1.11
GPU result: 18.49
